Wyze Home Monitoring: how to prevent System Armed if window sensors are open?
We usually Arm / Disarm the system using the Keypad which is far away from the base so we can’t hear the “sensors are open” message while arming.
Is it possible to have the system not arm if sensors are open?
It seems wrong to be able to arm the system if windows (sensors) are left open.
Regards
Jorge.
Unfortunately, Jorge, this is not a current feature option. Also, the Hub will not alert you with any audible message when arming with sensors open.
The only indication of sensors being open when arming is within the app with a red dot message:
This feature has been requested in the Wishlist. Follow the link below :point_down:, vote at the top, like any posts that appeal to you, and add a new post to the bottom with your ideas.
