Wyze Headphones - Audio Cable No Mic Support?
I see that the included audio cable is only a 3.5 stereo cable and doesn’t include mic support. Is this because the actual headphone jack also does not support mic. Really disappointed that I cannot use a cable to the headphone with a mic. This seems like a huge over site in functionality.
Welcome to the forum.
It’s normal for wireless headphones to include just a stereo cord, no mic. It’s really just there so you can continue to use the headphones if the battery dies.
Even $400 Bose and Sony ANC headphones don’'t include a mic in the cable.
Looks like they were thinking of doing more than just what competitors do and the connector does support Mic as long as you have a cable for it.
Check your cable. Does it have a built-in mic?
Wyze Headphones don’t include an AUX cable with a built-in microphone. If you’re using the headphones plugged into another device, like a gaming console, you must use a cable with a built-in mic.
The included 3.5 mm “TRS” or tip-ring-sleeve cable does not have a microphone. You must purchase a third-party “TRRS” (tip-ring-ring-sleeve) cable with a built-in microphone.
