Wyze Duo Cam
I have a Wyze Duo Ca which I just recently started to encounter lags.
Firmware version: 4.35.17.21
Running on 2.4 Ghz Network side of my router.
Cache cleared.
Note: Battery is draining very quickly.
Lag and faster battery drain showing up at the same time often point to a weak Wi-Fi connection, since the camera keeps retrying and stays awake longer. It might be worth checking the signal strength in the camera’s Device Info while it’s lagging, and if it’s low, trying the router or an extender a bit closer to see if both problems improve together. If the signal looks fine, I’d check next whether motion sensitivity or detection zones changed recently, since more triggered events also eat battery.
This camera does NOT have a battery. You sure you know what camera you have?
Wyze Duo Cam - No battery
Wyze Doorbell Cam Duo - Battery
I believe @jeremyc needs to clarify the cam but @tstockwood appears to be referring to the DB Duo Cam. Of course I could be wrong in my assumptions.
Wyze Duo Cams
For those of you who are encountering authentication issues with this device could be running into IP conflicts with another device on your LAN. Once you find the device assign a static IP address to the device and it will resolve your Wyze Duo Cam issue.
[Mod Note]: New topic merged to original topic for context/continuity and to conform to the Community Guidelines. Please avoid cross-posting the same issue as multiple topics.
Yes
That’s what I was thinking, too, based on the title, but the stated firmware version in the initial post doesn’t appear to match any firmware versions I’m seeing for Duo Cam Doorbell, so I have no idea what product is being used here or what the correct/appropriate tags for this topic would be. :man_shrugging:
