Wyze camera pan v3 works in egypt 220v?
Will wyze pan v3 camera will work on 220 voltage in egypt as it is usb cable with 5v ?
Don’t see why not, the included USB adapter/charger is 120-250V 50-60hz, you’d probably need a plug adapter to use it, or just use any USB charger/adapter that puts out 5V with at least 2000MA (10 watts).
If the adapter is 120-250v as you mentioned and here in egypt electricity is 220V so why i will need another adapter ?
Not a voltage adapter, just a physical adapter if the prongs are different than yours (not sure what style plugs Egypt uses). There may be country specific versions of the cams with different plugs too, not sure. Where are you planning on ordering it from?
The WYZE power adapters look like this. Doesn’t Egypt use round plug pins and wall sockets ?
Plug
Yes i will buy it from usa and yes i think i will change the charger itself only.
The input to the power adapter and the power cable from the camera that plugs into the power adapter are USB.
USB
Thanks all for helping :heart:
I just love how USB power is 5v universally. (Of course, amps is another story.)
Well not USB-C with PD but that’s a different animal. They do at least make USB-C stay at 5V until it negotiates a higher voltage with the attached device. But it is nice that the vast majority of wall adapters are 110-250V and 50-60hz which makes them pretty universal with a cheap prong adapter, which @mohamed_yehiaa95 may want to consider as they’re usually pretty cheap. Though most of us also have assorted USB chargers laying around (2A and up are a bit less common though).
Absolutely. I was amazed to find that out on my first trip overseas.
Unlike my friend who just assumed that all electronics support that now and melted her hair straightener :rofl:
Yeah. I remember someone plugging in a coffee pot. It worked really fast, once, and never worked again.
