Wyze cam v3 not turning on outside weather proof plugs. It is working when plugged indoor. Can someone advise.
Welcome to the forums! Are you using an alexa routine for this or Wyze app rule? Need more information on how you have this triggered. Which do you move indoor to help it work?
In situations like more more information is better for more focused support from the community. “Paint the picture”, tell us about your setup, anything that will help the process.
Thanks! :![]()
Have you checked that the outside plugs are functioning correctly?
