Wyze Cam v3 Image Rotation
I want to mount my Wyze Cam v3 sideways. That would require that the image be rotated 90 degrees or 270 degrees. You only have 180 degree rotation option. I suggest you have the option to rotate the image in 90 degree increments. Thanks [Mod Edit]
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
Here is the wishlist item for this:
