How do you setup email notifications if motion is detected on Wyze Cam v3 if this is possible? I looked at the app and cannot find it
Thanks
There is no setting for email notifications on the app that I know of. The only notification choices I see on my iPhone for notifications from the WYZE app. are sounds, banners and badges.
You’d have to look into 3rd party integration like ifttt or alexa to set up other than Wyze app notifications.
Welcome to the forums!
You might try creating a routine in Alexa that used email as a notification method.
