I have 2 Wyze Cam V2 cameras setup in separate rooms separated by a hall. The router is in an adjacent room. I’m hearing a sound on both of these cameras that sound as if it’s the same sound. It’s a ring type sound, slight pause, then 2 muffled words. I turn 1 camera off and I still hear it on the other camera. I turn that camera back on and the other one off and I hear it on that one also! I’m out of town currently for several days. If i was there, would a reset on each camera possible get rid of these sounds? I don’t have anything in these rooms that would be generating any sounds at all. Could these kind of sounds be coming from the cameras? I recently updated the firmware on both of them. I have 2 other Wyze Cam V2 cameras setup in other areas of the house and they are both working find. Any help would be appreciated. Thanks…
ive never heard of or seen anyone else post something like this. can you post an example of what you are getting?
Bam, take a look at this…
That sound is being played over and over about every 10-12 seconds! Same kind of sound is still is being picked up by the other camera down hall.
I’m not noticing the ring type sound anymore, just the 2 muffled words.
