Using Pixel 7a Android 14. The Wyze app running in the background is killing my battery. I use location for geofencing so I need to keep that service on,
Advice?
Advice?
Do you have the Android Battery Saver feature on or off?
Battery saver is off. That options should only be used when the battery is very low and you’re trying to retain the charge.
The problem is not my phone. The problem is the Wyze app!
I can go 2 days without recharging my Pixel 6 Pro using the Wyze App frequently. I hope you find a solution to your battery drain issue.
