I’ve been trying to add my wyze cams to Home Assistant using the Wyze Docker. I went to the websit to generate the API ID and KEY. When i copy it in to the Docker
login menu it says the API key has to be 60 symbols long. and it will not go any further. I counted and re copied to make sure i got everything but got the same response. Any Ideas ??
That is weird. I don’t get that error
I have one section for the ID and one for the Key Plus my login username and password.
Maybe ask in the Github area?
