WYZE API - 403 errors
Has anyone come across a 403 error when trying to use the WYZE APIs?
https://developer-api-console.wyze.com/i
I’ve confirmed all the API key/id user/pass are all correct and as per the page a MD5’d 3 times.
could it be because of the 2FA on the account login?
Not sure where you are trying to use this. I use it with Home Assistant and the Wyze-HA addon created by Mulliken. That integration requires the Key ID and the API key. I also had to put my User Account name and password. It works with no issue. I have 2FA set, but I don’t recall having to enter that. But could be wrong
