Is it just me or do the wyze cams have the worst motion detection software on the market? I tried using a V2 about a year ago to compete with my Arlo pros, and even with a TINY activity zone and detection sensitivity at 1/100, I would get constant motion alerts over literally nothing.
Now a year later, not only is setting an activity zone still broken on Samsung s9 (app freezes and crashes), the alerts are just as bad on the V3 cams! I have a tiny activity zone, sensitivity set to 1, and the tiniest disturbances to a single pixel in the activity zone generates an alert. It basically makes these cameras useless for home security purposes as I get an alert every single minute.
This sucks. I was really looking forward to replacing my Arlos but it looks like Wyze decided to put their effort into… watches? Headphones? A scale? Instead of something as essential to a security camera as reliable motion detection and alerts.
My V3 cameras do the same thing. The slightest movement or shadow triggers a notification. Even with things that happen outside my activity zone. It does the same with sounds. The slightest sound will trigger a notification. I was getting alerts every five minutes.
So I turned off my alerts and will rely on my eufy cameras to notify me. The Wyze cameras will be used to fill in what my eufy cameras miss.
I have never had that as a recurring problem. When I get motion alerts it is ALMOST always for obvious motion of trees, bugs, birds, squirrels, or humans. The old fashioned zone box and person detection (and disabling the LEDs) work well to refine that. I don’t yet have a V3 to compare.
Needs to be fixed to only trigger to motion inside detection zone. on windy days my camera spends all day pointed up at the tress that are way outside on the detection zone
Yup. I know the cams are old now but I bought two and they basically set off literally 20-30 motions a day / night. I spent many hours with support and downloaded all the firmwares. Right now I am using the v3 in the closet for a litter box to watch and I get so many alerts from someone even turning on a light in another room. I have the motion sensitivity to 1 (this seems to do absolutely nothing) and I also setup the notification area to a very minimal area and it does not matter. It’s like nothing in the settings on these cameras work. I ended up buying 14 cams from another manufacturer. The Wyze is downgraded to litterbox watch. The cameras have the WORST motion alerts in the industry.
