My WOC doesn’t detect the SD card in the base, can’t schedule recordings.
Greetings @rusty58 and welcome to the Community Forum! ![]()
The uSD card needs to be 8~32Gb and format in FAT32.
- Remove the uSD from the Base or Camera to test in your workstation.
- Format the uSD card FAT32 and un-check the default “Quick” option so it can mask out bad cells.
If you run into problems, recomend using This Standard Program to format.
- Using High Endurance cards in your device.
Info On HE Cards High Endurance Cards
