I probably shouldn’t be posting this since I know nothing about electricity but I’m giving it a shot anyway hoping that I will understand the info that I receive.
I have a 4 way light switch now that I want to convert to motion sensor switches.
The new switches have a lot more wires to connect. Attached are photos of each switch.
Number 1 switch will remain as a toggle or a compatible switch for the other 2 motion sensors.
I need some elementary steps on how to and to what each wire gets connected to.
4-way switch setups can get a bit tricky, especially when trying to integrate motion sensors. If you’re keeping one toggle and adding two motion sensors, you’ll need to make sure all the switches are compatible and can work together in a multi-way configuration.
The key is identifying which wires are the travelers, the line (hot), and the load. A multimeter can help with that, but if you’re not confident, it might be worth having an electrician look at it. Better safe than sorry when dealing with house wiring.
