Whats wrong with a cam seeing movement and then you hear a sound notifying you when your home? My cell in Kit. charging I’m in family room.
[Mod Note]:Your request was moved to this category for better visibility in order for you to receive help from the forum community. Forum Feedback is restricted to questions or suggestions about the operation of the forum.
If you have Notification Settings active (on) for Motion and\or Smart AI events on the cam you referenced, it will send a push notification to your phone when it detects that specified motion regardless of where your phone is located… With you or in another room charging.
If you don’t want notifications from your cam(s) when you are at home, you have several options:
turn off all cam notifications using the bell button in the home page
create a location rule to use your phone GPS to turn off notifications on that cam when you are home
create a shortcut button rule to do the same
create a schedule rule to turn off specific notifications during specified home hours.
