What does this Wyzecam error message mean on an Amazon 10th generation tablet?
I had to reset my generation 10 Amazon Tablet to factory defaults.
After I did this I get an error message when trying to display my Wyze V3 camera as follows:
Unable to resolve host “api.wyzecam.com
No address associated with host name
What does this mean and how can I fix it?
Are you able to browse the web and use other internet apps on your tablet since resetting it?
Thank you for your reply.
Before I saw your reply, I decided to try the 10th Generation tablet again. I made NO CHANGES to either the Wyze camera or to the Tablet.
I asked Alexa to show me the Wyze camera. To my amazement, the camera was correctly displayed on the Amazon tablet. Will see if the camera stays on. I have no idea why the display came on. I changed NOTHING.
I have no idea what the error message I received means.
Can you explain what the error message means?
My best guess is a DNS lookup temporarily failed. Retry, and it worked. The DNS server converts a text address to an TCP/IP address.
If it is currently working, you are fine. Chalk it up to a temporary glitch. :slight_smile:
Thanks for your reply.
The camera display is still on the Amazon tablet.
Thanks for your explanation of the error message,
I will chalk this up to a temporary glitch, as you suggested.
