Weird setup
So about a week or two ago I got in my 2 shipments of 3 black cams from Wyze and 1 black from Home Depot. Set the HD one up first, no problem. Set 3 of the straight-from-Wyze cams up, 2 of them “failed” but still showed up in the app labeled by their MAC address, no problem. Finally got around to set up the remaining 3.
Two set up fine, 1 would not give a voice prompt when I pressed the button. I tried plugging it in and holding it in for 10 seconds, 20 seconds, no go.
Gave up, laid it down beside me, sent a message to support, watched a little football. Probably was about 10 minutes after I laid it down it spoke. Picked it up, pressed setup, proceeded as usual. SEEMS to be working.
That is odd, not sure I would trust that one.
Yup, it’s “marked” I’ll use it where I can easily replace it.
Did the firmware updates work alright after you set them up?
Didn’t try that yet.I’m not deploying them immediately, just wanted to make sure they worked.
Still need to test SD card, IR lights, etc.
