Watch playback on pc?
Not sure if I’m posting in the correct category, but I have a Wyze2 and was wondering if there’s a way I can watch playback and/or monitor on a pc…?
You could remove the sd card from the camera and then place the SD card in a computer and look through the file structure to find the time of video you want to watch, or since Wyze does not have a PC app, you can actually run an Android emulator like BlueStacks then install the Wyze app within BlueStacks. Then in that app you can view SD card playback like you would via the app in your phone or tablet.
If you have a Cam-Plus subscription, you should be able to use https://view.wyze.com/ to access live and recorded events from any browser.
While the Wyze Cam 2 is primarily designed for use with a smartphone app, you can still watch playback and monitor it on a PC. Here’s how:
  1. Download Bluestacks: Bluestacks is an Android emulator that allows you to run Android apps on your PC. Download and install Bluestacks from their official website.
  2. Install Wyze App: Open Bluestacks, then use its integrated Google Play Store to search for and install the Wyze app.
  3. Sign in to Your Wyze Account: Once the app is installed, launch it and sign in using your Wyze account credentials.
