Watch Cameras on Tv or Screen Using Fire stick or Nvidia Shield or any other option
Just checked my post in the Tinycam Reddit about the missing app, and the developer said it would be “available on Fire devices within a week”.
Nice now if you would just return my email and give me a little bit a help it would be good. Although the only thing I need is just to get my CCTV cameras on there the Wyze cameras are easy to pull up. My CCTV DVR has an HDMI out on it but it’s very finicky on what monitors it will work on. I might try hooking it to my projector into HDMI two and then if I think there’s something outside do picture in picture on my projector and just bypass tiny cam pro completely
I think I may know what’s going on…
tinyCam picks up devices in the order you have them in the Wyze app.
In the tinyCam advanced settings for each camera you choose the ‘channel number’.
So, if your Livingroom camera is the trird one down in your Wyze app the channel in tinyCam is 3.
If you move Kitchen camera to the third spot tinyCam will show the kitchen camera but it will be labeled Livingroom.
I tried that. And it kept saying that number is invalid. And then it said as a tip move your cameras to the top of your app. So I did that and they kept moving back down. But with the new update that stopped.I’m going to re-try it now that the cameras are staying in their own place. The main thing that I want to add is my old CCTV cameras. Because pulling up the Wyze cameras on Amazon TV is easy. But I would like to be able to get the CCTV cameras also
Does anyone know if it works with fire tv cube?
There’s no reason it shouldn’t.
Have you tried it?
Not yet. Thought someone might have tried it.
You asked; “Does anyone know if it works”
What do you mean by it?
tinyCam is an Android app so it works on the Fire TV.
Tried with my current fire stick but it’s not in the app store.
I have it working on my Fire Tablets but looking to put it on the TV.
