Viewing on Windows
I have 9 cameras. From the original to newest pan and stationary. For the longest time Bluestacks worked great with the Wyze app. Then either Wyze or Bluestacks or both updated and now only 3 cameras work. The older models. 1 of which I have the paid plan on the others are all sd cards and just me watching on my monitor. I have tried 2 other Android emulators and even the recommended ones I cant get to work. All I wanted was to be able to see 4 of my camera’s on my monitor live.
Has anyone found and emulator that just works. Like Bluestacks used to?
Thanx
Lynn Weston
Running wyze app v3.7.8 (702)
Wyze cam v2 firmware 4.9.9.3006
Wyze cam v3. firmware 4.36.15.4389
Wyze cam v4. firmware 4.52.9.4188
Wyze cam Pan v3. firmware 4.50.15.4800
No subscription
I gave up on bluestacks. You would probably call me a conspiracy theorist if I said why.
I am now using MUMU Player. https://www.mumuplayer.com/ with the same app and firmware above.
It takes a little getting use to a few more clicks to do what I want, but pretty decent. JMHO.
I give up on emulators.
I just use ios ipad and android tablet updated to the Latest app and firmware as of 7/24/26.
The emulators worked pretty good when they did.
If anyone is looking for a relatively inexpensive tablet, check out the Samsung Tab A11+. I got mine at Walmart for $219.
It gets Samsung Android updated through December 2031.
I figure I can get many years of use for $219.
