Viewing next clip by swiping the clip
I have discovered what appears to be a bug in the process of swiping a clip to move to the next clip. Example: If you are at 10 seconds of viewing a clip and swipe the clip to view the next clip, the next clip won’t start at zero time, it will start at 10 seconds. That means that you miss the first 10 seconds of the second clip. If you have Cam+ and the clip is 40 seconds long and you swipe it at 30 seconds, then if the next clip is shorter than 30 seconds you will miss the entire clip. Anyone else experiencing this??
I occasionally notice the same under Android. It’s very inconsistent though. I haven’t experienced this problem under iOS.
I am experiencing this on my Samsung phone. It is happening pretty much every time that i go to view the camera clips.
