Is there a way to view multiple live feeds at the same time?
I don’t believe so. If you look through the forum you will see this discussed as a possible future update. I think we are all waiting excitedly for this release.
To find the topic, search #roadmap for “simultaneous”
Right now you can use tinycam on android or chromeos. In the future they are coming out with simultaneous streaming before the end of Q1 which is March 31st.
This has recently changed with the newest BETA update. Its AMAZING!! Hopefully it will be integrated for all users in the future.
actually, this feature is only in Beta right now.
Thanks for the clarification. My bad!!
