Video feed scroll restarts after watching any video
I found it, but i don’t know where I can update it. Do i need to go to google Play Store and find it there?
Update…I did find that I could update it from the play store and the problem is no more. Thanks!
Just days after the update, this issue has returned in full force as of yesterday at least. Status please?
Please update your Wyze app. The latest version is 2.45.6.361:
I went to your lonk and then clocked on her link to the google Store, and it shows for a split second and then keeps saying page not available.
I just uninstalled and reinstalled from the Google Play Store and it’s working fine.
Here are some tips…
If you are running Android beta 2.46.0.b360, you can’t install production 2.45.6.361 (version number conflict). If you are running beta and wish to install production, uninstall beta 1st (not sure why you would want to do this though).
If you are installing on a non-standard Android device (e.g., Fire tablet), you most likely need to sideload from other than the Google Play Store.
If other, reboot your phone/tablet and retry from Play Store.
I realized that I don’t have a problem with the event section, so will update at a later time.
