V3 Longer Cable
Does anyone have a recommendation as to what brand of cable to for the V3? I probably only need 20 feet. Thanks!
I’ve a post on here comparing 3 long cables with V2’s from Amazon but it was about a year or so ago and besides being difficult to to find the companies change so often it might not be valid.
That written all three worked with my V3’s this year.
I have various lengths of these cables, with 42’ being the longest. They be come in various lengths
MOYEEL 42.5Ft(13M) Power… Amazon.com
They were powering cam pan cameras outdoors fine for over a year, now they are powering v3 cameras which I assume require less power.
If you are using longer cables, I also recommend using a USB adapter with a higher rating than the one supplied with the camera. Longer cable = voltage drop = glitches
Here is the adapter I use for these long cable runs
Anker 40W 4-Port USB Wall Charger… https://www.amazon.com/dp/B00VH8ENXE?ref=ppx_pop_mob_ap_share
