Using Wyze Cam Pan with Google Nest Hub in Canada?
Is the feature for Google Nest Hub integration with Wyze can available in Canada? I cannot get it to show or setup.
Hi, @Mito. Per the below support page,
The Wyze integration with Google Assistant is available worldwide but is currently only supported in the USA. Please note that your success may vary if using the Wyze integration outside of the USA.
Hi, so I still have the same problem after 9 months since this question have been asked. I can cast Wyze cam pan to chromecast but it doesn’t work on nest hub. When will this integration be available in Canada?
