Google hub assistant
Hi is anyone having problems with getting the Wyze Cam V2 and Wyze Cam Pan getting the camera to work with google hub assistant my cameras don’t show up on my google hub assistant
Hi I have tried all multiple google devices and voice activated still the same all my Wyze Cam V2 and Wyze Cam Pan cameras still the same asked google to show me the car Park black screen comes on with red lines going up and down
that’s it thanks
MR GIOVANNI TURCO
Sorry I couldn’t help, but it sounds like your problem is above my pay grade. Hopefully someone else will jump in with a solution for you.
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, please file a Support Request. You can also submit a request from within the Wyze app by going to Account > Help & Feedback > Submit a Log. This method will allow you to send an app log for diagnosis as well as report your issue. (Note that if you are using a beta version of the app, the log will be sent to the dev team rather than Wyze Support and will not generate a support request.)
