No problem at all. Personally I would not go for the V3 Pro. That is a 2K resolution and I don’t think your 4Mbs speed can handle it.
And if you can’t figure how to do something the first times, go to YouTube, and search. It may not have the exact model of an item you are using, but more likely than not, there will be dozens of videos. So, check out 3+ for the general idea how it works and I bet you can figure your own out right away.
Thanks, habib. Honestly, it is the Edge AI that got my attention. You’re right about the 2k. I’d have to drop to probably 360. But I’m wondering if the Edge AI will save any time. Our Outdoor V2 takes about 25 seconds from trigger to cellphone notification. Any thoughts about how much the Edge AI might shave? Thanks!
I couldn’t tell you as I don’t own a V3Pro. Hopefully someone who has one can chime in and enlighten you.
