How do you keep the power to the camera when you have two outdoor lights but only one camera ? We didn’t want the non camera light to stay lit 24 /7
The power must be on to the cam all the time. One option is to get the smart bulb that is designed to pair with that cam and put it in the other light. You can then control both of them without having to turn off the switch.
The alternative involves rewiring stuff and probably isn’t feasible for most.
Welcome to the Forum, @sctrice! ![]()
What are you using for this light? If it’s Accessory Bulb and you’re trying to use it with Bulb Cam, then you should bind that to the Bulb Cam within the app and use the app to control both the Bulb Cam’s light and Accessory Bulb.
What other detail can you provide about what you’re using and what you’re trying to accomplish?
