I have a camera in my shed. I would like to take a Wyze plug and when the camera detects motion turn on the light. Is this possible? If so how would I go about doing it?
Tap … then select Add/Edit Rules. Create a new Device Trigger on your camera. select Detect Motion. Tell it to turn on the plug. Create a second rule to turn off the plug after it has been on for a period of time if you wish.
It should be noted that there will be approximately a 12-second delay before the light will turn on. That’s because the camera motion detection is based on when it notifies the phone, which isn’t until it uploads the video. If you need the light to turn on immediately, you’d need a Wyze Sense motion detector.
I added a motion sensor. I have a light plugged in to a wyze plug. How do I get the light to turn on when motion is detected and to turn off when motion stops.
