Turn off spotlight on Battery cam pro
In the spotlight setting unable to toggle off motion detection. I don’t need the spotlight where I have it mounted.
if you don’t need the spotlight, go to the settings area, select Spotlight, the turn off Sunset to Sunrise. The Spotlight will not come on unless you turn it on.
Thanks. I will try that.
