Total weight lost
I just got my Scale X and can’t seem to find where my total weight loss is in the app. Is there a place where just the pounds lost appears? Thanks
Welcome to the Forum, @myoung1229! :wave:
If you’re looking for a weight change displayed as a single number (the difference between your current weight and the very first weight measurement you took, for example), then the app doesn’t directly do that as I understand it. depending on what you want to do or how you plan to use this number—the total weight loss—there are some things you could do:
  1. The app shows your weight (and other metrics) history in graphic form, and you can tap on the graphs to see different data points.
  2. The app gives you access to your weight and other data history in list/table form, which you can export and receive via e-mail in spreadsheet form.
  3. You could go into your Scale Settings and set My Goal as your initial weight, in which case the Scale’s main screen in the app would show you a message like “You need to gain [some number] lb to reach your goal.” That would be one way to show cumulative loss if you’re just looking for a single number display, but it wouldn’t be the typical way to use the My Goal setting.
Thank you for that information. It was very helpful
You’re welcome. If you’re have difficulty finding what you’re seeking and detailed instructions and/or pictures would help, then feel free to let me know.
I was looking for the same answer. One would think the total weight lost would be displayed loud and proud. It’s the reason why I bought the scale as I am on a weight loss journey. How frustrating that this important number isn’t possible to see!!! Come on Wyze, this is a huge let down
