Thermostat control on android watches
I have a Samsung watch ultra and want to adjustmy thermostat temperature settings from my smart watch. Is there an easy enough way to do this that isn’t a bunch of steps in Google?
Welcome back to the forum @andreporter2.
Natively you cannot do this with the Wyze app. But you can with Google Home.
Not exactly sure what too many steps with Google means for you though?
Do you have Google home setup today? If so you can install Google home on your Ultra Watch and will have access same as Google home is setup
Sorry for the late reply. I meant too many steps as in having to make 4 or 5 clicks to navigate to the thermostat option in Home on the watch. Secondly, when I try to adjust the temp from my watch on GH, after clicking th + to increase or - to decrease it fails and shows a msg with “Something went wrong”. It works fine on my phone in GH as well as the Wyze app. I have my watch connected to the same wifi, bluetooth is also connected. Turning lights on and off through GH on my watch is doing fine as well. I’m at a loss for where the hang-up or obstacle is. I tried to unlink the Wyze app and re-link. That wasn’t fruitful. I have considered a complete reset from the ground up of the GH app, factory reset of my watch, and the Wyze up. That’s a bit much though.
