Switch the order of Cameras. Make Cam 2 show as Cam 1
I need Cam 1 to be the Camera that is called Cam 2. Anyone know how to switch them? Thank you!
Easy to re-arrange them. On the main screen where it shows the various cameras (and groups if you have groups), select the pencil in the upper right corner. Then Edit Devices. That will show all of your cameras. To move the order, simply grab the two horizontal lines on the right and drag up or down as desired. When completed moving cameras and groups around, select “Done” in the upper right corner.
If you want to change the name of a camera select that camera from the main screen and then the gear in the upper right corner. At the top is the camera name. Edit as desired. After editing the name, select “Save” at the bottom of the screen.
Lots of helpful how-tos and tips on the Support site: :+1:
THANK YOU !!! Lois >^…^<
Thank you So Much! It worked!
Yep! It’s actually stated in a link that was posted above by @Seapup …
It’s actually a “=” sign. Not three lines
Thank you so much. All solved!
