I can’t find a way to add “Step Counter” to watch face. I tried all the watch faces available. Any idea?
That’s not an available feature at this time on the 44
Thanks but bummer! Another useless watch in my drawer
Wyze is pretty good about adding features along the way.
Is it available on 47, I see pictures show it has.
Yes, it is available on the 47.
Thank you for the quick response!
Has the Google Fit syncing issue been fixed as well? I see several people have complained about it and no resolution yet.
Google fit seems to be syncing fine for me… But I’ve never used it before so I don’t have any experience with it to compare.
I tried with 44. It syncs for the first time after enabling it. It does not sync in the background mode. It will sync only after I open the app. If I don’t open wyze app on the phone for a couple of days, the google fit doesn’t sync at all. The wyze does run in background mode in my phone. I am not sure this problem exists in 47 as well.
I got the watch 47. It has the same problem with google fit. It syncs heart rate periodically just fine. But steps, it does only for a few times in a day and never catches up previous day’s steps when it syncs next day. Could you please report this as a bug and have your developers to enable the full sync of the steps?
Is step counter available on Watch 44 now?
Didn’t you say you had a 44? Are you just trying to get other people to do your look see? lol
