Solar Panel by Wyze
Can I use the solar panel for other Wyze cameras, IE Wyze Pan cam 3??
The solar panel only works for the battery powered Wyze cam outdoor. Other cams don’t have batteries and won’t work.
Solar panels that are sold to be paired with IP Cams are not designed to power the cam, only to charge the batteries within cams that are powered by batteries. The solar panels do not have the sustained power output capable to power a continuously powered cam. That would require a much larger panel and peak sunlight 24\7.
