Smart Vision Open Beta Feedbacks Thread
I got a skill created, trained and enabled. So far it hasn’t detected change-of-state. Will keep playing with it
Same here.
When/if this is working, it will be very useful - thanks Wyze!
I am having the same issue.
  • IOS User
  • iPhone with Wyze Beta
  • iPad with Wyze Release
  • One V2 Camera with Cam Plus
  • Many V3 Cameras with Cam Plus
  • One Pan V2 with Cam Plus
  • One Outdoor Wireless with Solar and Cam Plus
None of these are showing up on the Smart Vision List for me.
I am still reading through the forums, but do we know if this initial sync to the camera is via the Cloud, Direct over Network or Bluetooth?
I was able to get to the Smart vision easily, When I try to create a skill I do not see any of my cameras in the list. After reading over the Forums it seams that V3 and outdoor cameras are not part of this test?
Will
I have the same problem, same App version.
Same here.
(post deleted by author)
Capture from past events not working.
When you choose that option screen turns white and freezes.
Two issues on my @#$%^&* iPhone 8 with iOS 15.6.1 and Wyze version v2.37.0 (b4).
First of all, on the I accept the terms, popup, you have to check the checkbox and THEN the 10 second countdown timer starts before you can click Continue. This does not do this on Android.
Second, when trying to set the attention zone, the green box shows the entire image and the green dots at the corners can not be moved at all. This is also not the case on Android.
The skill I set up earlier today has now started working - events are being tagged ‘door opened’ or ‘door closed’ and notifications coming to the iPhone. Further refinement that would be good might be to only send notification if state changed … right now it’s windy so camera keeps sensing motion in the porch from stuff flapping around and normally I would get no notifications for that but with smart vision turned on it keeps notifying me about that open door now :slight_smile:
Like many people here, I don’t see any cameras show up. But then I don’t have a V2 camera so at least that explains why.
The other issue I have is that on my old Google Pixel 2 phone the “Next” button is obscured by the “Create My Own” radio button.
Seems like the skill is kind of working now. It might take a day or something for the cloud server to update and apply. The skill wasn’t working yesterday but started working at 8 am PST today. Skill is tagging the video “light off” for each state change even when it is the light turning on.
I’ve got lots of feedback re experience using the Beta Testing Manual. Unable to upload here so emailed to @WyzeMengtingHu
Still no tags on my 2 cameras that I setup last night.
Maybe needs more time still or more photo examples?
Can’t delete existing images.
Push pencil in images folder and choose select.
I can put a check any image.
Clicking Move or Delete doesnt do anything.
IOS 16.1
Having the same issue. Can’t get past trying to capture images from either previous events or live feed. Android app just goes to a white screen and locks up the app
It’s buggy. Past event capture hasn’t worked for me. Capturing from live view is hit or miss. Took me many tries to go though the setup process from start to finish (maybe 10 tries?) and successfully connect to the live view to capture each state.
Trying to add my V2s to the beta program but that camera isn’t listed as an option. Can see V1, V3, etc. just not the V2.
Running beta App V. 2.37.0 (b4) on iOS (iPad and iPhone).
Do you have Cam Plus or Cam Plus Pro assigned to your Cam v2? Also need current firmware 4.9.9.1472.
