As this is an early test, v2s are the only currently supported cams. They have said other cams will come, but for now a v2 is required
Yea the help page seems to be broken. Not sure if itâs private or something, because it prompts you to login to view that page
On IOS, the icon for smart vision is the same as the services tab. On android it has its own icon
I donât have a v2 either. Also help page broken for sure.
I attempted to create a skill based on a door open. I could select my cameras (the one I was trying to use is a V2). I got to the capture photos, but donât really have any idea what I was supposed to do, and could not get past that page.
Ya⌠no cams seems to be an issue.
I have mostly V2s and a V3 Pro. None are showing in the Select a Device screen. The âI donât see my cameraâ link just goes to the Help Center home.
This is exciting
One question . I have the floodlight camera and also powered up an additional v3 through the back usb port
Bc I have such a overly sensitive pir sensor and deal with constant false motion light activations I keep an eye on my floodlight
So what Iâve done is basically turned on motion notifications from this v3 to get notified of whenever the floodlights come on .
What I would like to do is since this is available in the feedback pop up for event feedback is to be notified if light changes
So when my v3 detects the floodlights turning on itâll notify me of this event and not of every single other motion event such as bugs , rain , my cat walking past the camera , wind , spiders , spider webs , and every other motion event
Will this be possible ?
Cams showing, but capture from past events causes app to freeze
One more question: Is a CamPlus or CamPlus Pro account required for this feature? If so, Iâm not a candidate for testing this feature. I have neither.
Smart Vision is the ability for you to train for some events you are interested in. Not sure you saw in some of the AMAâs or other, but they showed things like Garbage Can is out, or car in garage, etc.
At this time, you have to have a V2 to use it.
What goes in the create your own labels? I canât get past this. Tried door closed, door open, etc.? Wonât enable Next option
Android 10 Samsung Galaxy Note 9
v2.36.0 (96)
Your new little program is bugged from the beginning, canât even scroll the first set of instructions. Half of the paragraphs are cut off by the âNextâ box.
Also, your device list is completely missing!
Back to the drawing board guys!
When I try to create a skill, none of my cameras are listed to select.
Currently this process requires a V2 camera
Add me to the no cameras show listâŚ
Very different results between iOS and Android. On the iOS, I was unable to set the attention zone because the zone was the entire screen and it would not let me move the green dots for the corners.
Also figured out that I need to take multiple photos in each state. I will have to wait till I get home -kinda hard to open and close the front door from 26 miles away!
Only allows me to use it with my Wyze cam v2. Clicking I donât see my camera brings me to a login page that says I need to enable cookies but the continue button doesnât work
I have a v2 in the garage, still doesnât show up in device list.
