Smart Vision Open Beta Feedbacks Thread
Font size has nothing to do with it, the next box covers everything. You can type your label name, but the next box never changes to be able to continue.
Edit: you can’t see what your typing either.
I have v2 camera but do not have CamPlus or CamPlus Pro
Some more description and examples of skills would be very helpful. What kind of objects or conditions can be used. For example: person carrying a package/bag, person walking, blue vehicle, person at night, person exiting vehicle, person moving left to right, person with red shirt/coat, rain, snow, animal (dog, cat, deer, racoon, squirrel, skunk, snake, bird), something present for x minutes, something detected before and/or after times, etc. Can it only be very specific subjects that can be provided in training photos? Maybe I totally misunderstand what a skill means.
Ok,
so this what im going thru with this smart vision.
As mentioned before, i have v2 cameras, but only i was able to find the one with the cam plus service (already mentioned).
I have a Samsung fold z 4 and trying to create my own skill on the smart vision area, When youre at the point of taking photo from past activity videos, the page goes completely white and seems to freeze app as soon as you take photo from the video in the cam plus cloud. Basically i have to turn off the app, to be able to restore. App version is v2.36.0 (96)
Thanks. Finally got through to start creating a skill. Have three working V2 cameras listed. Just need to think of the best use case.
:thinking:
Got app setup and a “skill” setup… Only confusing point was selecting a camera(s). Only one of my 5 that showed was not a good location for a “door opening” skill. So I tried to follow the path to “select other cameras”… I could never log in to whatever I was logging into (on the app) to look/select my other cameras. I used my normal login ID & PW, but nothing would go thru…
So I modified my skill on the one camera that was listed to monitor the garage doors rather than the service door.
When trying to add pics i got this white screen
I updated everything and cleared the app cache and it resolved the issue
Now waiting for it to trigger
Great usage for old cams BTW
Got to the point of trying to capture images. It froze with a white screen after I tried to capture images from the past.
I meet all of the requirements but still get the white screen of death when I try to use past events.
My Stats:
Camera: V2
App: 2.37.0 (b4)
Firmware: 4.55.0.104
Cam Plus Applied
… and I am still not seeing the camera in my list of camera for Smart Vision.
So I went the app store and updated the app hoping that it would do something for the new Wyze vision beta test. As far as I can tell, it did not.
But now, I can’t upload pics in the threads.
ANYONE else?
4.55.0.104 is the current Cam v2 firmware for exclusive use in the Wyze Car. This firmware version cannot make use of Smart Vision and Cam Plus features. If you removed your cam from the Wyze Car for this test, either manually flash back to regular Cam v2 firmware or just do it via the Wyze Car app directly (with your Cam v2 connected to the Wyze Car):
From the Wyze Car app home page, tap your user icon in the upper left:
Select “Switch Cam mode”:
Find your cam in the list. The button for your cam should read “Use Camera Mode”. Tap that button and the firmware will revert the cam back to a normal Cam v2.
After you’ve successfully updated your Cam v2 firmware, apply Cam Plus if you haven’t already done so.
So these are the issues I’m seeing when trying to train a new skill. I can’t capture the images needed. When I go to capture from an existing video nothing is in the results for events. I’ve successfully created one skill & trained it but no notifications occur from it
Tried again today, was able to get through the initial setup of a skill with live pics and capturing from a past event. Cloud apps certainly render obsolete the old definition of insanity.
Now I’m just waiting for the weather to improve so that I can get more default and event pics without getting soaked.
An observation would be to have more info/tool tip help defining what training actually means.
Or maybe that definition of insanity is still correct…
It says I have one image uploaded for the open state… But when I click into it I see:
@WyzeMengtingHu
Seems to be kind of working on Android 12.
Current skill is set to track the status of one of the cars in my garage. It takes a while after creating a skill for the event videos to get tagged with the skill tags. Some videos are not getting tagged but I guess it is still learning. Definately running into a lot of bugs when creating the skill though. Mostly the bugs happening when trying to capture intial status photos.
using the AI to detect “spagetti” with my 3D Printing business
On my 4th attempt to set this up, I was able to do so, but, I had to use 2 devices that had the Wyze app. All attempts to capture from recent events failed. The events loaded but we’re not accepted by the skill at all. I can capture live images both open and closed. App is 2.36.0.96 because the Google app store still doesn’t have the beta update yet that was released several days ago. My cams all have Cam Plus. My V2 garage camera has 4.9.9.1472. And I could not use the skill in my phone because today the skill pages have blown up to where not all of the content is viewable or scrollable, so I had to do the setup in my tablet. I did check the page display size in the phone and it is not expanded in any way. This did not happen yesterday. My phone is Galaxy S20 and my tablet is Galaxy S6 Lite. Both are on Android 12, One UI 4.1. And this is odd. When I go into Smart Vision on the phone, after adding an image for both open and closed and enabling the skill in the tablet, the skill is listed on the phone, disabled and with no images. Both devices are running the same version of the Wyze app.
Pixel 6 Pro
Android 13
Wyze Beta v2.36 (96)
All devices updated and most have Cam plus
No devices show up when I try to add a new skill.
Are cams V2’s?
Try clearing the app cache
