Thanks all for your input.
Well, this is where I stand now. None of my 5 cams (without Smart Plugs) have dropped OFFLINE in a while. Wyze Smart plugs failed too often and could not be put back online without unplug and plug.
Therefore, since I run my cams continuously and am going to be able to reset them if they go OFFLINE because I will be home mostly for now.
However, I’ll purchase some KASA Smart Plugs and have them at hand in case I do run into cameras dropping offline. But I’m going without any Smart Plugs for now while I’m home. Then I will give Kasa a try If cameras begin to drop offline.
As I said, Wyze Smart Plugs I found did drop off too often for me. Removing them seemed to solve (at least for now) that issue. However, I will not hesitate to insert Smart Plugs if necessary.
