Shared User Permissions
I have 3 devices i share with a family member. I have problems when they decide to turn off the camera on there end through the app and I can’t turn it on when they forget to turn it back on. I have to wait for them to be available to tirn it back on. Can this be changed so that the main user decides to give permission to certain features for each device. I still want to give them access to the device I just prefer to not grant them the power to not shutoff my device when they choose.
I log my wife into the Wyze App with my User Name and Password. I ask her not to turn off cameras but if she does I can turn them back on.
The two solutions are - tell them not to shut off the camera or you’ll unshare it. Or create an automation to turn them back on every hour (if they’re already on, it won’t do anything). Not sure why you can’t turn them back on though, granted it has been a long time since I messed around with the guest account but pretty sure you could turn them back on if someone else turned them off.
The real mess is if they create an automation. Your account can’t see the automation, so you go crazy trying to figure out why things are changing.
Welcome to the Forum, @JoeTech! :wave:
You should check this topic:
As with any Wishlist topic, you can visit that one to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
As mentioned above, I’m puzzled by this bit:
Why can’t you turn it on? As the owner, you should be able to do this at any time, as long as the Cam has power and an Internet connection.
