To day 11/19/2026 on my Samsung A37 cell phone when needing to check video play back across 4 cameras I had noticed SD card was in light gray like it was not installed, then a few minutes checking my other cams some were ok and then not. then when it was showing and I went to check play back footage I had noticed that some of the cameras had no blue timeline ribbon. but dose display event symbols. no way all 4 cameras had the SD cards go bad all at the same time. they work and then they don’t for the SD play back. The play back screen just says ( No Video Available At This Time… )
Looks like some of this started happing around 1;23am on 11/18/26 or that is at least when the blue ribbon ends along with any play back video to see.
So with it working on some cams and then stops working when I check again later I am thinking it may be a Wyze server issue.
So who else is having issues with play back and it looking like your SD card is missing???
@Dans-Cams Since it hit all 4 cameras at once and comes and goes, I’d agree it’s probably not the cards. Two checks would narrow it down. First, open one camera’s settings and go to Advanced Settings > Local Storage. If it still shows the card and its capacity there, the camera side is fine and it’s the app failing to load the playback timeline. Second, try playback once with your phone on the same Wi-Fi as the cameras and once on mobile data, and see if either one loads. If you want to be sure the footage is actually there, power off one camera, pull its card and look in the record folder on a PC. If there are folders dated 11/18 and later, it kept recording the whole time.
So this morning at 4:43 am I had a PIR driveway sensor go foo alerting me of movement around my car. so I went and went to check play back on two cameras that watch over that area. 1st being the Wyze solar Pan cam that has USB power so to continuous record and the 2nd camera is a Cam Pan v4 4K set to do the same continuous to the SD card. both of the cameras were missing any play back of that event.
So this morning I went and checked my V2 video doorbell cam the cam pan v4, the solar pan cam and my duo pan cam too . each camera had timelines and symbols for events that may have happened for person, Pets , vehicles and even talking. and for the most part the light blue ribbon shows’ on the timeline, but then one cam has a gap of like 20hrs the light blue ribbon is missing and any of it’s play back during that time and then starts again from Nov 18th to the 19th.
the duo cam I see many spots in the light blue time line ribbon during the night that have small gaps of 10 seconds to 3 minutes of missing footage.
Now for the solar pan cam the footage that was missing last night and early this morning of the 4:43am event had footage of the light blue timeline missing for big gaps of hours of it’s SD recordings finally showed back up this morning and I was able to see it was a big stray cat that set off the PIR sensor. odd that the pan cam v4 and solar pan cam never triggered it as an event but days back both cams that cross view that area recorded a skunk and noted it as a pet.
So this USB continuous recorded footage is likely on all the cameras cards still, and I am for the most part wheelchair bound so I cant get up a ladder to pull SD cards to check the footage.
But seeing that this issue is with all my cameras and each has it missing at different times and then maybe showing back up again points to an issue beyond my home network failing or cameras.
So I am assuming that when remote play back viewing is done by use of my phone it is requesting it through the Wyze servers to pull it back up from my cameras and that it is some how an issue with the servers causing the missing play back when requested.
Seems like I am seeing a lot of servers across the country this month going down or hacked and wondering if that is the issue with Wyze or maybe they are being serviced causing the play back loss .
In my past I had installed CCTV systems with DVR’s & NVR’s on a closed system non relaying on internet and cloud off site storage to avoid this kind of issues and hacking. Thinking now trying to save some time and money going with Wyze instead of a closed home based system was not a good choice.
and the biggest pit fall is having my storage in the camera it self. if the network or server fails come winter time it will be a lot harder to remove any SD cards needing a ladder to reach them and not dropping them in the snow opposed to just having a small NVR in my nice warm home. and if any factory or network connection resets need to be done I would not to have to go out and hold a reset button on the camera.
Guess I am to use to and spoiled working with IP cameras and NVR’s that can all be config. from my warm home on my PC.
