Can you resequence your camera list ?
Yes. Select the pencil in the upper right corner, and then select “Edit Devices”. That will list all your cameras. You can grab the two horizontal bars on the right and drag the order around as desired. Remember to click “Done” in the upper right corner when completed or your changes will be lost.
If you are talking about the cameras in a group, select the gear in the upper right corner, then the number of cameras to the right of “Cameras in Group”. Then same procedure with the horizontal bars. Only this time, it’s “Save” in the upper left corner to save.
