Replacing IFTTT
Now that IFTTT is reducing their free routines… Again, I was hoping that I can find alternatives to some of my applets. Besides IFTTT, is there anyway to turn on or off all cameras and enable / disable motion detection? It looks like both alexa and google don’t work.
Thanks!
Any time I find that Alexa can’t do what I want her to do because she lacks the Triggers or Actions, I still put her to work but keep it simple for her.
I employ a Wyze Plug. To have Alexa turn off all my cams, I set up a Wyze plug named “All Cams”(nothing plugged into it, just sitting there waiting to relay a message to my other Wyze devices). I tell Alexa to “Turn Off All Cams”. Then I create a rule that when the “All Cams” plug turns off, turn off all cams. I have another plug named “Cam Notifications”. “Alexa, Turn Off Cam Notifications”. When the plug goes off, a Wyze Rule mutes the notifications. I then have opposite rules to turn them back on when the plug comes back on. “Alexa, Motion Detection Off”… Wyze plug named “Motion Detection”… Wyze Rule when it goes off.
I bought plugs in bulk when they were on sale for this very purpose. I only have a couple left and had to employ power strips to plug them all in.
The possibilities are endless. Any action on any Wyze device can be triggered by the On\Off of a Wyze Plug and is therefore able to be relayed from Alexa.
I hear you. I was hoping to avoid new hardware, and another ecosystem where I need to create rules/routines.
Hopefully this is forwarded to Wyze automation programmers @WyzeJasonJ
I guess this is one way to sell Wyze plugs :face_with_raised_eyebrow: but unlikely to get many new customers …
Sadly, I may start looking for Cams that are better integrated with Alexa BUT I do not want to. :confused:
You may want to look at the brands Amazon owns, Ring and Blink. Recent Alexa positioning moves in the IoT sector seem to indicate that it is gearing toward a transition to a more restrictive cross-ecosystem automation integration platform. It will more than likely become a proprietary hardware preferred automation platform. The signs of an impending subscription paywall for alien hardware and\or numerous integrations are already being seen.
Thanks and ….
I am OK with an appropriately priced pay wall, as Alexa does provide some excellent integration across platforms.
