Removed wyze beta program
I was having a lot of problems while on beta and I finally removed beta and what a difference it makes now. I deleted wise app and added it back and now I’m in heaven….
You steal have the beta badge in your avatar :slight_smile:
Didn’t know that. Not sure how to take it off
You can select “(None)” or something else (“Team_Android”, maybe?) from the drop-down list in the Flair section of your Account Preferences, but it probably makes more sense to just visit the page for the Beta Group and click the  Leave button. Leaving the group should remove it from your available Flair options.
Thanks. I did delete that but still there.
Thanks. I just deleted it.
You’re welcome. Sometimes Forum pages require a refresh before the changes actually show. I see this happen pretty frequently when I change my profile picture. :grin:
If you still want some kind of profile flair, then you can take a look at the Groups page. Like I mentioned before, you could join something like Team_Android (or even re-join Beta at a later date) and then afterward should be able to see that as an option under Flair in your Account Preferences.
More frequently than your socks :rofl:
Not true! :socks:
:grin:
