Power Over Ethernet (POE) extends power to the Wyze cam, AND adds wired internet, right?
Are there any posts that feature before and after footage captured by a POE-connected Wyze cam? If there’s any quality boost, I’ll start looking into what everyone’s using. Not sure if this is just an “extension cord” benefit, or it’s also a quality or perhaps just stability boost. Thanks.
PoE only adds power. WyzeCam only connects via Wifi. I use them all over the place.
Do you have a link to this device?
How did you get one up that high? That’s pretty impressive!
This is that poe to 5v power. Plugs right into the Wyze Cam
https://www.amazon.com/dp/B07WCGY7KJ/ref=cm_sw_r_cp_apa_i_TfZaFb7FDAP2N
Note: since this photo, I’ve started protection them from the elements using PVC pipe. They are not designed for outdoors but they do last a while on their own. 1 didn’t.
Thank you @ryny24, that is a good recommendation and a cool “use case”. Going PoE like that would not only probably make my Wyzecams a bit more stable, it would prepare me to easily move on to better cameras without issue.
Here is how I protect them now. 1.25" PVC pipe with cap. hole for a ty-wrap at the bottom. micro-usb extension cable OR y-splitter if 2 cameras. done.
From my experience, some of the contrast and clarity of images thru the cameras can be altered via software.
