WYZE Wireless to POE
Dear WYZE,
I have many CCTV Cameras that I bought, that problem that I encountered was most of the time no signal. Is there any device that my Camera can convert to POE instead of wireless
Not sure what you are asking, but if you want to use Wyze cameras with PoE over Ethernet cables you can use this sort of adapter to convert to 5v USB connections at the camera end.
https://www.amazon.com/WT-AF-USB-Splitter-Ethernet-Switches-microUSB/dp/B019BLMWY0
Welcome to the Wyze community @cargoaa.guam!
There’s a Wishlist item, it’s currently marked as “maybe later” so Wyze has it on the list but it’s not a priority.
Click the blue “vote” button to vote for this idea!
Edit: you can use a poe injector like @Customer suggested, but it will only provide power.
