Panning Cam Pan cameras in the Alexa app
I don’t view my Wyze Cam Pam cameras through the Alexa app very often, but I just noticed that you cannot pan them in Alexa. Intuitively it seemed like you should be able to. I can pan my Alexa Show 10 device, just not the Pan Cams. Is this expected behavior? If so, perhaps a good wishlist item?
Does Wyze write and maintain the Alexa Wyze skill?
How do you get the Alexa App to stream your cams? Every time I try it tells me the Cam doesn’t Support that or that it isn’t available on this device.
I can stream them on my FireTV Stick, but not in the App.
I haven’t seen development and improvement there in a very long time.
I dunno, it just does.
Thanks for pointing out those two wishlists. Just voted them.
