I have no subscription, using 128gb SD card. When there is motion detected it only takes a photo and no video. Is this the intended function? If so then it’s useless and I’ll return it.
No it records video to the SD card but it can be confusing. Right below the image is a “play” button but that is for the cloud recording. If you have no subscription, it will just show an advertisement. But below that at the bottom is an “SD Card” icon, tapping that will play the video on the SD card.
You can also go into the cam live view, tap the SD card under that, and browse around the SD card recordings that way.
