Outdoor cam pan case that permits rotatation
Does anyone have a cam pan outside in a case that rotates? I see ones that pan and tilt but not rotate. This one in the questions says it does but Amazon question/answer isn’t reliable.
Wyze Cam Pan Protective Case with Wall Mount Bracket, Weather Proof Adjustable for Indoor and Outdoor Anti-Sun Glare and UV Protection Very Easy to Install (White) https://www.amazon.com/dp/B07GCX831T/ref=cm_sw_r_cp_api_i_bS5wEbRF1BPQ8
Yes, I use this one and it pans just fine. The camera functions normally inside it.
Wyze Cam Pan Protective Case with Wall Mount Bracket, Weather Proof Adjustable for Indoor and Outdoor Anti-Sun Glare and UV Protection Very Easy to Install (Black) https://www.amazon.com/dp/B07GCYF2T8/ref=cm_sw_r_cp_api_i_wq6wEb4657C7H
So it rotates just fine? Do you have issues with the cable tangling at all? I was looking at this which I think is the same but in white. Lol
No issues at all. The case does not go below the camera body so it does not actually get anywhere near the cable connection.
That is the same one I picked but in white correct? I may have to paint the lip black for glare control
They look to be identical other than color. It’s a flat texture and color so you should not have any issues with glare.
Settled in on these. No issues with rotating at all.
HOLACA Real Water Resistant Protective Case Amazon.com
Thanks. I was looking at those also. Thanks for letting me know that they will work perfectly. Again a maven comes thru. Lol.
