Outdoor Cam Continually Triggering
This Outdoor Cam triggers every few minutes. I’ve lowered the detection settings to very low levels, I’ve deleted the camera from the network a number of times and started fresh, and I’ve put it in a dark box with nothing for it to “see”. Still it just keeps triggering. Five other outdoor cams on two networks work just fine.
Any other ideas?
TIA for your help.
-bjk
Can you post your Event Recording Settings, You Notification Settings, and your Detection Settings?
Sure! Thanks for the quick reply!
Detection Distance and Sensitivity: Currently both at 40%, but it’s been set lower with no difference in triggering
Event Recording: Detects Motion is enabled
Person Detection: Currently enabled, but it’s been disabled with no difference
Notifications: All are enabled
Thanks again,
If your notifications are set to all Motion (Other Motion), then you will get notified on every little thing.
I have my event recording set to all, but notifications, I uncheck all and set the AI items I want to be notified on. Primarily person and pet.
